An S15 to me is just some JDM Fanboi taxed thing
What and a £10k 20 year old Skyline isn't?
You said you have only driven an auto S15!![]()
). Loved the instant response but felt very twitchy when pushed into oversteer however the suspension wasn't stock in my mates car so maybe not a good example. Engine very good and still quite tunable (I had fun after my mate supercharged his) but again brakes felt very soft. Lots of styling parts so you can make it unique, my mates was bright yellow with yellow/black kelvar/carbon fibre boot/bonnet and wing which looked "interesting!"
What and a £10k 20 year old Skyline isn't?![]()
Here you go, a wildcard, probably comes in quite a bit under budget too:
http://www.pistonheads.com/sales/4262289.htm
I fancy some rear end action also![]()
[TW]Fox;22850916 said:Where abouts do you plan to do that? I think most trackdays throw you off if you start drifting![]()
Insure prices aren't a problem and I've driven many a fast car before hand so the jump won't be a problem
I'm swaying towards the Silvia as it will be a daily car and I fancy some rear end action also![]()
Are you looking at 14s too?
I have an S14a I spent two years working on before I ever drove it, treating all the rust. I had a lot of performance parts on my old S14 I transferred over to it.
The S15 chassis is pretty much the S14 chassis but with extra rigidity parts welded into various places, so retains the lightness and balance that makes these cars so popular with the drifters, but transforms the feel of the car into something much more solid according to people who have made the transition.
The S15 has a better turbo, bigger injectors and a 6-speed close ratio box as opposed to the 5-speed in the S14s. Many after-market parts are interchangeable, making them one of the cheapest cars around to tune. Standard injectors and turbo should see 320bhp.
The brakes are a weak point, good pads certainly help, but although the 4 pot fronts are okay, the single pot sliding calipers at the back are best ditched, assuming they are the same as fitted to the S14, the R32 conversion being extremely popular.
Mine is wearing R32GTR front brakes, and R33GTS-T rear brakes, stops quite well with the brakes from the heavier Nissan on the lighter car
I being biased would have course say get the S15, as a daily drive the power of a modified GTR is going to be wasted, and the higher running costs will drag you down. The S15 might be harder to handle particularly in the wet, but driving a car at legal speeds being a challenge is going to be more rewarding than being bored at the same speed. Hence why I believe you are looking at these cars and not the sort of machines fitted with traction control and heated seats?
I think the GTR is of the age where you have to have some passion for the thing too. Rust might be a concern and getting a good one that hasn't been abused by many owners lacking the budget to maintain them properly might be a problem, although the price of the GTRs does somewhat keep them from the fate that a lot of the cheaper Skylines and 200sx s have suffered.
Another car to consider is the 350z or the 370z if that falls in budget. It's a bit more modern, your budget should get you a nice one and with a few modifications they sound very well indeed and make over 300bhp too.
300bhp is absolutely fine in a road car. There are very few opportunities to make use of more these days, the amount of speed cameras and speed traps. With 300bhp you only get mere seconds of the loud pedal before you are doing licence losing speeds. If you've never driven that sort of power before it takes some getting used to not being able to keep your foot down constantly.
Good luck, whatever you choose will be fun. Have you also looked at the BMW and Porsche models that fall into similar power and price brackets? Even some of the diesel BMWs can be very quick with a remap.
The standard engine is reliable upto about 300-320hp.
