somethings up somewhere as direct x should install fine,try installing it as admin
Found this on another forum, strangely enough it came about from sleeping dogs as well:
Ya the thing with the service pack is what I was saying you need to right click the Direct X 11 file and go the advanced or compatibility tab and deselect the option that was running the file in windows vista compatibility or instead you need to select it to run as vista with service pack 2.
Try this as well:
For other Steam users, the file path is: program files/steam/steamapps/sleepingdogs/redist/dxredist/dxsetup.exe
It's to do with the game not installing the right files for dx11 which high and extreme options need. I'm out of ideas mate.
Reinstall driver time.![]()
Have you disabled onboard graphics in the BIOS? I was thinking maybe its interfering with installing dx drivers as it could be detecting igpu and not graphic card?
