Not sure if this should go in here or motors tbh, but oh well, I have a petrol generator ala http://shop.smallplantrepairs.co.uk...Path=/Shops/es106741_shop/Products/3000petrol
It used to run fine, hasnt been started in about a year and 2 months, 4 months spent covered in the garden (protected from rain) and the rest in a lock up facility.
We cant seem to get it started, have tried the usual, make sure there is fuel, checked the choke settings, apparently the oil has been checked, only thing that hasn't at this point is the spark plug, I am going to pick it up this evening take it home and check the plug.
When you switch it on and try to do a pull start it sounds as if its going to start, coughs a bit then dies.
Considering its not been started for a while do you think it just needs some TLC? any tips on getting this started? I am going to trawl through google when I get a sec later.
