Caporegime
- 18 Sep 2009
- Dormanstown.
Ha, no need to be confused.
For you the i5 3570k would still be the better CPU.
not when you have an equal oc headroom on a higher performance baseline at stock for the i5.
But the AMD will be substantially cheaper.
Because I don't want to bottleneck my 7970 with an awful FX CPU and my 3D performance would be abysmal?
Also you'd have like 40% headroom left in the tank in the i5.
So when the AMD user has to blow another load on upgrading their CPU and Motherboard likely, I can continue to use my i5.
Take the i7's launched back in 2008, they're lasting fine (They also OC'ed a massive amount), but the Phenom II's launched in 2009?(They struggled to get 4GHZ stable consistently for a long time, took a silicon revision and it still wasn't consistent) Bottlenecking GPU's left right and centre.
AMD's "value" argument is fallible these days.
You told me though that a stock 2500K won't be a bottleneck paired with a good GPU at 1080p. If the AMD CPU can match the stock i5 then why spend more?
It isn't at all though.
Definitely not when you have to upgrade it first.
Buy AMD if you think it's best for you, just don't go telling us about the value argument.
With the headroom the i5 Ivy's have, they may even last to a point PCI-E 2.0 is a bottleneck. Not a problem, they've got PCI-E 3.0. AMD owners? Nope.
It won't be 100 pound cheaper to go AMD at all.
You're literally ignoring everything.
You'll be pushing a 5800k to the balls to not bottleneck a GTX670, come next GPU? Oh wait, you're bottlenecking it.
An i3 3220 at sub 100 quid (Likely mirroing the 5800k price) wouldn't bottleneck a GTX670 while costing the same amount, using less power.
It costs about £250 to go the Intel route versus perhaps around the £150 mark for AMD.
For gaming at 1280 x 720 / 1366 x 768 / 1680 x 1050 < an AMD Trinity build would be sufficient without a dedicated GPU. Save a lot of money to..
At 1920 x 1080 and above an Intel build + dedicated GPU would be a better build![]()
What?
It doesn't cost 250 quid for the Intel route at all.
You can get an i3 3220 and board for 135ish.
i5 3330 and board for about 175ish.
Seriously, I give up.
I am talking about the 2500K. That would cost around the £250 mark.
That is hopefully what the AMD CPU will compare to.
LOL,at this thread. People are debating the performance of CPU which is being released in the next few days,probably tomorrow. Wait for the reviews. Simples.
That is hopefully what the AMD CPU will compare to when overclocked.
.But you can clearly state without a shadow of a doubt it isn't going to have i5 performance at stock as it stands out of the box, it just isn't going to happen.
What is the main use of the PC you are going to build??
They are in different price bands so are not really comparable TBH. The Trinity A10-5800K will probably be around £90 to £100 and a Core i5 3570K is around £170 to £180.
The reviews are out this week for the Trinity A10-5800K,so we will soon get to know how well it performs at stock and when overclocked.
If you need a decent IGP and/or a CPU which after some overclocking should be reasonable,the A10-5800K looks a good alterntive in its price band.
However,the Core i5 3570K has a worse IGP but is simply a faster CPU,which is better suited for a high end gaming system.
