AMD cards are better value overall, but the quality of drivers and options to tinker with sways me towards nVidia everytime. Just so much to toy with.
Do you get things like adaptive vsync and such with AMD drivers these days?
Hi,
Now need a vid card...Considering the ICEQ here as discussed, http://www.overclockers.co.uk/showproduct.php?prodid=GX-065-HS
A few Q's...
1. My PSU is a OCZ600MXSP (it has 2 x 6pin plugs ready to power card) - I take it this PSU is powerful enough?
(Computer spec: i7 2600k, 8gb 1600 mem, 1x120gb SSD, 1x1tb HDD, 1x2tb HDD, 1x DVDRW)
2. Although this card only has 1 visible DVI port, I run 2 monitors. Can I easily connect 2?
TIA
Mark
I would get the MSI, only because the warranty seems a lot better.Geo-Gamer said:its true best bang for buck looks like its the 7950's when overclocked as they have massive amount of headroom. However,im buying one today or tomorrow but im stuck in between the msi tf3 and the his iceq![]()
It seems after 28 days if an HIS card goes wrong, OcUK end up having to send the cards back to HIS in China/Taiwan for repair/rma.
This guy has been waiting 16 days already. Check this post >> http://forums.overclockers.co.uk/showthread.php?p=22879388
Maybe it doesn't bother you much as it does me, I worry about these things lol, but in my opinion MSI owns the throne for AMD warranty, with Nvidia your looking at Gigabyte, EVGA, KFA2 or MSI in that order, all good really.
They make good cards, I've owned a vapor in the past. Sapphire usually take at the very least of 3 weeks, if you do a google of 'Sapphire RMA' you will see people waiting over 28 days, but no rma should take longer than 28 days, if you get to 28 days then you contact the retailer to sort you out.Geo-Gamer said:thats a very very good point i dont fancy waiting around for a card to be repaired hahaI just noticed the saphire vapor -x oc. How is that looking agaisnt the msi tf3?
