Don
- 20 Oct 2002
- Oxfordshire / Bucks
Seems like the best place to get advice. Thinking about picking up a road bike for commuting to work at the weekends. Just been checking out the bay to pick something up second hand.
What sort of size do you think I should be looking at? I am 6'2" and my inside leg is about 34.5". Looked online and it suggests 58-60 size frame. Sound about right?
Any named makes that I should look out for? Thanks
going by my recent encounters, i am also looking for a road bike,, im 6'2 and i was suggeested a 58 at first, so went to a bike shop and they asked me to try a 58 out and it was too small,, i then tried a 60 and it was a good fit. my inside leg is about 31 though, i would suggest you goto a shop and sit on one, and they will tell you to look at the front hub in 3 positions to clarify
