Ugh marked my partners car
[TW]Taggart;22879409 said:
for referance, a clay bar is what you should have used to get tar off.
I found the claybar only gets off the loose ones. Buy some Tardis for a few quid off ebay as that stuff works well and get a 3 pack of microfibre clothes from a supermarket/homebargains for a quid.
Don't whatever you do use T-cut as it actually takes the clear coat and a layer of paint off when it's probably only a surface scratch. Use some decent polish and a bit of elbow grease and that should come out ok.
Little update with good news :D The guy from work give me some Turtlewax Safe cut Scratch remover and it worked a treat with a little elbow grease
My Girlfriend no longer looks as if she wants to kill me :D
Time to sort the wheels out now. :p
Was thinking that myself but it's only really 2004/2005 C3 Second car for her to do shopping in and school runs. Maybe new hubcaps?
Well chuffed atm there was more than one part of the car marked but was to embarrassed to show my handy work :D
Glad you got it sorted Bigpig.
I can't even begin to explain why this is wrong on so many levels. :o
You do realise that all polishes remove paint by their very definition? You also can't remove a scratch without levelling the surrounding paint to the deepest part of the scratch.
If you can remove the entire clear coat and a layer of colour coat with a single application of T-Cut then you are doing something badly wrong. You aren't supposed to apply it with steel wool...
A neighbour's son (was was a bit of a thicky) used a brillo pad on his mum's car to remove some tar spots.
Not actually ;) I'm fully aware how polishes work thanks. Polishes are a light abrasive, where as T-Cut is basically paint stripper.
I remember using T-Cut on my old faded red MR2 turbo before I sold it and the cloth was literally turning red as the paint came off. Looked good when it was done though, although I doubt it did for long with no clear coat. Next person to view it bought it :)
For minor surface scratches you just want a light abrasive to level out the clear coat.
I remember using T-Cut on my old faded red MR2 before I sold it and the cloth was literally turning red as the paint came off. Looked good when it was done though, although I doubt it did for long with no clear coat.
That sounds like solid paint with no clear coat. You won't have removed it - it never had any applied.
try and get hold of a rotary, that will get it out with some compound
yes. rotary is the best bet. Hand polishing is only good for small spots. rotary is great and you may be tempted to give the whole car a once over and use some zainos sealant (ideal for silver cars)
This is my car with just sealant. I have since polished it with rotary and applied sealant to it. So it looks a lot fresher (but no pics yet).
