- 15 May 2012
- Louth, lincs
What are they like?, would look good in my rig and got aquaero 5 on its way.
Both as the D5 offers both...
That koolance top does look nice, expensive though.
So for a pump/top what would you recommend, loop will be 2gfx blocks, cpu, 240x80 and 360x80 rads.
Colour has to be black and maybe if top wAs seethrough/acetal and would like to control through my aquaero5 controller to make a fully automated system.
In otherwords when running low intensive tasks the system should be almost silent and as intensity rises so should flow rate, fans, etc. this is why i asked about the pump in the op, can it be done with another pump/make??
Edit :What about the alphacool HF d5 top in plexi?
Is your pump just sat on the sandwich or have you somehow screwed it down?
Nick, what about the one I linked to, it's tougher Acetal so good for first timers like us, and it's well reviewed![]()
Looks good mate, loving the sandwich
So although that top looks great, would you recommend an alternative for a first timer?
So on compression fittings, finger tight + 1/4 turn with grips???
