- 5 Aug 2006
- Derbyshire
This is the best thing I've done to mine so far. Take some out the base to make a bowl shape for you to sit in, and there's a whole section of the backrest which will pull out as one piece. Makes the seat feel like a proper bucket and hugs you tight round the corners.
The seat took me a long time to take apart as the screw that held the back and base together (not the side with the big bolts) was a real PITA to remove. Also the hog rings were a pain! I will use cable ties to put the seat back together.
I am thinking of cutting foam out the base, as if it is cut out the top then the seat cover will not fit again properly.
Did you cut foam out the entire base or just the bit that sticks out a bit?
The bit of foam on the back that easily comes out . Won't it make the back of the seat look saggy?
