It's currently on 1.210V, if 4.3/4.4 fails, how much do I up it?Give 4.3-4.4 a try. If prime fails up the vcore a little. (only a little, baby steps.)
I'm not sure what is the current LLC, I'll find outWhat is your LLC? Level 6 seems the best for OCing to that level.
Should I set VCore to Auto or Manual?Give 4.3-4.4 a try. If prime fails up the vcore a little. (only a little, baby steps.)
Can't seem to find LLC in BIOSWhat is your LLC? Level 6 seems the best for OCing to that level.
I'm using Alpenföhn Matterhorn CPU cooler with two Corsair fans like this one,Same motherboard and cpu as me, similar overclock but you are getting much better temps. What cooler are you using, and what setting in the bios?
well done!
I'll set the VCore to Manual and leave it at 1.210V and try 4.3GHz, if it fails, what do I up it to?Vcore on Auto will give you higher voltage. Manual is your best bet.
I leave other settings as default?I think 1.25-1.3v should be about right to get you to 4.5, Lower may suffice. silicon lottery.
Is it SP120?Nice set-up by the way. Im getting a set of those fans for my H50.![]()
What do I set the VCore Load Line Calibration to?LLC, look at your second screenshot (first post). "Vcore Load Line Calibration"![]()
I'll try that todayIf it fails raise the vcore by 0.010 until it passes. Like I say 1.25 should be okay.
What does Level 6 do?Set the LLC to level 6 for now.
Should I use Turbo or Extreme for LLC?The LLC controls how the voltage changes under load situations. This is why the voltage shown on cpu-z may be different to what you set in the bios.
from what I have read and tested, level 6 is the most stable, ensure the voltaage doesn't exceed what you set, by much. Its a good place to start.
On the Gigabyte Z77 motherboard, it doesn't have Levels for LLC, it has Low, Medium, High, Turbo and ExtremeSorry mate, don't know what you mean?
Sorry for the bump, can someone help me pleaseOn the Gigabyte Z77 motherboard, it doesn't have Levels for LLC, it has Low, Medium, High, Turbo and Extreme
Overclocking,
Using a i5 3570K as mentioned, getting to 4Ghz was easy, all I had to do was set the CPU ratio to 40X, disable Turboboost (or leave the CPU ratio alone and set all four Turbo ratios to 45X if you want the power saving feature) and save+exit the BIOS.
Next up was 4.5Ghz, using these settings
CPU ratio of 45X
Turboboost disabled
LLC set to Turbo
Vcore set at 1.325v
4.6Ghz with:
CPU ratio of 46X
Turbo disabled
LLC set to Extreme
Vcore set at 1.35v
Thanks, I'll use Turbo for LLC, also the settings I've at the moment, is it power saving mode? As I don't want the CPU at full load when it's idleFound this thread mate: http://forums.bit-tech.net/showthread.php?t=230363
A good 3/4's of the way down is this bit:
Overclocking,
CPU ratio of 45X
Turboboost disabled
LLC set to Turbo
Vcore set at 1.325v
4.6Ghz with:
CPU ratio of 46X
Turbo disabled
LLC set to Extreme
Vcore set at 1.35v
Hope this helps.
