- 8 Apr 2012
- North wales
hi guys is it possible to get a p35 or p45 motherboard thats socket 775 and takes ddr3 ram ?
Im pretty sure ddr3 wasnt around at the time of p35 so that is probably out of the question. It has been a while but iirc there were a couple of higher end p45 boards that took ddr3. X48 boards also take ddr3 if you are interested in those?
You don't want a P35 over a P45 although I don't think you can get a P35 that takes DDR3, By the by the P45 is a much better clocker, Still run one myself with a Q6600 4Gb of ram & a 4890.
i need to know what boards support q8400, ddr3?
all x48 and p45 boards will support the q8400. I think just about all X48 boards support DDR3 too. It will be listed if a board is ddr2 or ddr3 when you buy it. So as long as it is either an x48 or p45 and is listed as ddr3 compatible you will be fine.
i need to know makes and model so i can try find one these boards
I will see if I can fish a few out. If you are looking on auction sites then just type in x48 motherboard or p45 motherboard and see what comes up. Most will have their specs listed![]()
Gigabyte GA-EP45T-USB3P
Btw 4T5 your sig made me laugh lol. Do you have plan to kidnap somebody?![]()
You'll need to come with me & take the same journey as the others to get the answer to your question.
