- 3 Jun 2005
I'm deliberately not giving any details just yet, but if you're not sure what you're looking at, my desktop has been shrunk to half screen and doubled vertically.
Ok, here’s the story:
It is the R7970 – it gave no signal from either DVI port, or any of the 4 MDPs using the enclosed MDP-DVI adapter, or my own MDP-DVI adapter. I got that image by waiting for Windows to load, and then pulling out the DVI cable and putting it back in, but I only got that image from one of the DVI ports, the other was still no signal. There was no signal at BIOS from any port, but Windows was making the noise it makes when a new device is plugged in as I tried each port.
I returned to OcUK and apparently it has tested as fine and is now on its way back to me. I literally just removed my MSI R6970 and installed the R7970, nothing else changed.
But here is the really odd part, about a year ago I bought the R6970 and it had exactly the same problem as is showing with the R7970. I returned it to OcUK where it was tested as faulty and a replacement was sent. The replacement was fine and is still fine to this day.
How queer.![]()
When mine failed it was like that at every resolution, and during POST etc. The GPU was fine; the picture displayed correctly with a different monitor. The duff monitor either didn't work at all, or had a distorted picture when tried on other machines.
What did you expect? After all you are duff man.
