*** Kupa UltraNote Windows 8 Tablet ***
It's now available for pre order in America. You guys will be pleased to know its now black.
Delivery early march, no uk pricing or pre order yet.
KupaX15-Elite
$1099.00
Intel Core i5-3317U 1.7GHz
64GB SSD
8GB RAM
Windows 8
KupaX15-Pro
$1199.00
128GB SSD
8GB RAM
Windows 8
KupaX15-Lux
$1299.00
128GB SSD
8GB RAM
Windows 8
Integrated 3g
KupaX15-Ultra
$1599.00
Intel Core i7-3517U 1.9GHz
128GB SSD
8GB RAM
Windows 8 pro
Integrated 3G
The KUPA X15 is a German-designed (manufactured in China) tablet that delivers what early adopters and enterprise users want: well-engineered & high-quality manufacturing combined with modular, versatile design. With its array of features, options, and durability, the KUPA X15 is quite unlike any other device on the market.
Intel Ivy Bridge i5/i7 Processor
Intel Ivy Bridge Processor gives the X15 desktop-like performance in a tablet form.
8GB DDR3 RAM
Its 8GB is a remarkable amount of system memory in a tablet computer. It makes the X15 ideal for running resource hungry applications while remaining mobile.
10.1" IPS 1920 x 1200 Screen
The X15's 10.1" IPS Screen has class-leading resolution of 1920 x 1200 and an ideal aspect ratio of 16:10.
Active Digitizer + 10 points Multitouch
The KUPA X15 offers both an active digitizer and a 10-point multi-touch screen. The digitizer fully supports digital inking under Microsoft Windows and is pressure-sensitive up to 1024 levels.
Side-loading Removable Battery
The X15's side-loading design allows its battery to be removed for extended field operation. This feature and the battery in the docking system (external battery charger) gives users even longer battery life.
Broadband Connectivity
The X15 is compatible with 3G (on select models).
Notebook PC Docking System
The X15 has an optional dock with keyboard, extra battery, Ethernet port, VGA port, SD card slot, and USB port. This gives the X15 a notebook-like experience and extends its battery life. The keyboard is very comfortable for long-duration touch-typing.
Modularity
The X15 can be customized to meet every user's specific needs; with an external side panel that can be fitted with a card reader, scanner bay, video recording unit, projector etc. (Note that we only recommend buying the X15 after your desired module has been released, because the notebook return window will not be extended for any reason, including module release delays). The internal memory and mini PCI-E slot allow further customization to meet enterprise requirements. .
