Ok what am I missing, the nVidia has more memory, higher minimum and maximum FPS but has a lower score... what?
Lower average FPS.
You clearly missed my previous post that saying Heaven Bench has no bearing on real world gaming performance...as it is only good for showing purely the graphic muscle, but doesn't identify things like CPU bottleneck. And the reason why I specifically said "single player games" is that they general don't tax the CPU as much, comparing to online games which are generally much more CPU demanding. The how much horse-power and engine has means very little, if it was paired with a car with poor set of wheels.Half the price & similar performance = "pretty alright"
*picture/comment indicating correlation of palm and face not included - feel free to imagine your favourite one*
Are they loud? My 8800gtxm was like an aircraft taking off, hated it, will probably never buy a gaming laptop again.
Now have your facepalm aim back toward yourself.
http://www.kitguru.net/components/g...e-f2a85x-up4-amd-a10-5800k-review-w-discrete/
yeah I can see what you mean? All that bottlenecking. Just look how it performs compared to the cheap Intel. These figures are from the desktop variant. Thing is unless you go i5 or above trinity actually appears the better deal and be prepared to pay more for the intel.
Sadly game's default benchmarks often don't push the hardware as hard as the actual gaming environment, and the high frame rate on the Shogun 2 says that much. And the kitguru's review, looking at the game list it in fact reinforce my point of AMD CPU would be fine for "single player" games on most part? Shame they don't test games under the situation where CPU matters.http://www.kitguru.net/components/g...e-f2a85x-up4-amd-a10-5800k-review-w-discrete/
Shogun 2:
Guild Wars 2:
I bet someone's gonna go and say but that's a 7970 at 1280 res bah bah bah. The reason reviewers always use low res for testing CPU scaling is to remove GPU bottleneck and look purely at CPU performance. The low frame rate on the AMD CPU in Guild Wars 2 for example means that even people with a lower card like 6850, even with dropping the graphic settings in game, it still wouldn't push the frame rate above what the CPU can deliver.
Weird as it may be, but may be Shogun 2 is that one game that Ivy actually do better than Sandy by that much of a margin? I mean it's not every day that a game would even be any better on a Ivy comparing to Sandy since it would always be GPU bounded first or hitting 60fps anyway on most games. Either way, the Phenom IIs looks about right considering the IPC...The results on that Shogun 2 are whack, 5GHZ 2500k performing the same as a stock 3570k?
For BF3 on multiplayer, it's about know what the realistic setting to be use with what graphic chip.As stated in your first post, you have proven the new A10 4600M is up to the job in GPU intensive games. I'd be very interested to see some realistic games that require some CPU usage like a heavily populated BF3 server. That way myself (and others) can see what the best mobile CPU is. I am interested in getting a gaming laptop so am quite eager to compare various mobile components.
Weird as it may be, but may be Shogun 2 is that one game that Ivy actually do better than Sandy by that much of a margin?.
Any luck with the GTX 680M results yet?
Actually the normal settings performance pretty much says it all about the CPU performance differenct between the two laptops. Intel's minimum 45fps and averaging nearly 60fps is much more playable than AMD's minimum 22.9fps and average 39fps.Hi there
Here is the Sleeping Dogs results, the 7970M is on top when visual settings are all set to extreme, which enables AA/AF I believe. However setting to normal so AA/AF is not on the 680M platform seems to have a big performance pull back, beating the 7970M, maybe thats the faster processor flexing its muscle?
We sell both laptops so I have no personal gain by saying buy the cheaper one, but I've run the benchmarks requested and pretty much proven my point, the 7970M AMD based laptop offers superb 1080p gaming performance, if thats your aim your not gonna find a better gaming laptop for the money. If the 680M Intel laptop was £200 more, then I'd consider it, but even if you remove the SSD, larger screen, bluray, your still talking an additional £500. I'd simply not spend it.
Of course the best option all round shall be when AMD release the hotfix for Enduro problem, then you can have full blown 7970M performance with Intel processor.
But please those saying that AMD Trinity is a bad match with 7970M is miss-leading, its just as capable in games at 1080p as the more powerful Intel based counterparts which cost considerably more.![]()
As for extreme setting, I feel that I need to point out that Sleeping Dogs would use SuperSampling under this setting, and as far as I know, Nvidia cards don't handle SuperSampling as well as AMD's cards, so the much bigger performance drop on the 680M comparing to 7970M make sense. However despite the 7970M is faster than the 680M at handling SuperSampling, looking at the minimum and average frame rate it is still not playable performance. Even on the desktop PC platform, I don't think there are many people would play the game under Extreme settings, unless they have at least a highly overclocked 7950, and/or have at least minimum 35fps.
How about the Shogun results then?
Regarding playable, I found Sleeping Dogs was perfectly playable on both machines at Extreme settings as did others here.
Facts remain the MSI 680M is twice the price of the MSI 7970M machine, my money would go on the 7970M machine because at 1080P it plays the games fine.
However a better solution would be an Intel based laptop, with 7970M with Enduro hotfix and also for under 1k. I am working on making this possible right now.![]()
For the Shogun 2 result...can you comparing the minimum frame frate while having lots of units on screen at the same time?
Any chance MSI be releaseing a simliar spec gaming laptop to the AMD's one, but with the Intel CPU/platform for may be around £1300?![]()
