**WINDOWS 8 NOW AVAILABLE FROM OCUK (FREE SHIPPING)!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Microsoft have moved the planned date for taking Pre-Order to now!!! :D
As such the following is now available for Pre-Order and you shall recieve your copy of Windows 8 for October 26th, the day of launch:-
Microsoft Windows 8 Pro Upgrade - from Windows 8 @ £49.99 inc VAT
Microsoft Windows 8 Pro Pack
If you currently have a personal computer running Windows 8 standard edition, then you can upgrade to Windows 8 Pro (Professional). With Windows 8 Pro, you can connect and share your files. Windows 8 Pro also adds enhanced features if you need to connect to company networks, access remote files, encrypt sensitive data, and other more advanced tasks.
The new Windows 8 start screen is your personalized home for items you use the most and can be customized according to your user preferences. Windows 8 Live tiles provide real-time updates from your Facebook, Twitter, and e-mail accounts. Along with the new Start screen, the lock screen now includes e-mail, calendar, and clock widgets.
To access your PC, Microsoft has replaced a standard PIN or password with a swipe gesture; unlock your PC by clicking or swiping preset locations you’ve selected on the lock screen. New functions also allow you to search for your favorite software programs, open, close, hide, resize, or run multiple apps simultaneously with the swipe of a finger or a swipe of the mouse.
Windows has also made changes to make your PC more secure by boosting its existing security features and adding "SmartScreen," which acts to prevent suspicious programs or apps from being installed or running on your machine. Finally, Windows 8 also gives you the ability to "refresh" itself to give users a new starting point and a cleaner version of Windows.
You can upgrade to Windows 8 from Windows 7, Windows Vista, Windows XP, Windows 8 Release Preview, Windows 8 Consumer Preview, or Windows Developer Preview, but you might not be able to keep all of your files, software programs, and settings. The following table shows what you can keep during an upgrade, depending on the current version of Windows you are running. If you choose to boot from removable media, you won’t be able to keep your software programs, Windows settings, or personal files when you upgrade.
Your Windows, everywhere - Perfect it once, have it always. Sign in to any of your devices running Windows 8 and your personalized settings and apps are right there.
Connected to your people -Your apps light up with connections to your friends and family. Info from the services you connect to Hotmail, Messenger, Facebook, Twitter, LinkedIn, and more appears right inside the Mail, Messaging, and People apps.
Connected to your files - You use multiple PCs and a phone. Now you can connect across these devices to SkyDrive, Facebook, Flickr, and other services, so you can smoothly get to all your photos and files.
All the Apps you want - Apps are the heart of Windows 8. You’ll be able to get up to speed quickly with a set of built-in apps for the things you do the most. Designed for your connected lifestyle, these apps integrate with the services you already use.
Built-in Apps - With Windows 8, your entire PC is cloud-connected. You’ll have new Microsoft Mail, Calendar, SkyDrive, Photos, People, and Messaging apps that are connected to services like Facebook, LinkedIn, and Twitter just by adding them to your Microsoft account.
Apps work together - In Windows 8, apps work together so you can share information between them and streamline your work. For example, the Photos and Mail apps are connected, so you can select a picture from an album in your Photos app and email it to one of your contacts with a single click. No more opening your mail separately and attaching the picture. You can enable apps to include content from SkyDrive, share with your contacts in the People app, and send mail to people you know.
Make it yours - Make your Start screen your personalised home for the things you care about. Organise and customise it the way you want.
Fast and fluid - Built for speed, Internet Explorer 10 brings you a faster web. Whether you're loading sites, sharing sites, or going from sites to apps, it all runs at a speed comparable to apps on your PC.
Intuitive - Browse with ease. There when you need them, tabs and navigation controls appear at the swipe of a finger. Share sites with friends—just swipe and tap. And pin sites to Start for one–click access.
A more trusted Web - More security, more privacy, more peace of mind: Building on innovations like SmartScreen and Tracking Protection, Internet Explorer is designed to work with the security platform of Windows to give you greater control over your personal info and help keep you safe from the latest online threats.
Great experience across many different devices - Because Windows 8 can run on low-power CPUs, you can work much longer on a single charge. That means you can stay connected so your PC is ready when you are. Battery life is longer and connections are stronger so you’ll be able to find a device to suit you for work or play. Lower power requirements are also helped by the growing number of energy-efficient devices that are designed to work with Windows 8.
Share between devices - Tap and Do works on mobile devices equipped with Near Field Communications (NFC) so you can tap two devices together and share information. Tap and Setup is another feature available with Windows 8 that lets you easily connect wireless devices, like keyboards, mice, headphones, and speakers by simply tapping them against your PC. No more PINs or complicated setup steps!
To It's Windows reimagined and reinvented from a solid core of Windows 7 speed and reliability. It's a touch interface. It's a Windows for devices. And it's easy to try now - whether you're installing it for the first time, or moving from Windows 8 consumer preview.
Features:-
- Upgrade Windows 8 to Window 8 Pro
- Media-less PKC
- Launch offer at this price
Only £49.99 inc VAT.
ORDER NOW
Windows 8 Pro Upgrade Edition - from XP SP3 / Vista / Windows 7 @ £49.99 inc VAT
If you currently have a personal computer running Windows 7, Windows XP or Windows Vista then you can upgrade to Windows 8 Pro (Professional). With Windows 8 Pro, you can connect and share your files. Windows 8 Pro also adds enhanced features if you need to connect to company networks, access remote files, encrypt sensitive data, and other more advanced tasks.
Features:-
- Browse and discover great apps in the Windows Store
- Sign in to any of your Windows 8 PCs and instantly see your settings and get your apps
- Store your music, photos, and docs in the cloud with SkyDrive
ORDER NOW
Microsoft Windows 8 32-Bit DVD - OEM (WN7-00367) @ £79.99 inc VAT
Cloud-Connected:-
Your Windows, everywhere - Perfect it once, have it always. Log in to each of your devices running brand new Windows 8 and your personal apps and setting are available, straight away.
Connected to your people -Your apps light up with connections to your most important people. Information from the services you connect to Hotmail, Messenger, Facebook, Twitter, LinkedIn, and more appears right inside the Mail, Messaging, and People apps, at your finger tips!
Connected to your files – Connect across multiple devices you use everyday like a phone or PC, SkyDrive, Facebook, Flickr, and other services, so you can smoothly get to all your photos and files.
Apps:-
All the Apps you could ever want – Applications are at the epicenter of Windows 8. You’ll be able to get in the know quickly with a set of built-in apps for the you need the most. Designed for your connected lifestyle, the apps merge with the services you use daily.
Built-in Apps – By using Windows 8, your whole computer is “cloud-connected”. You’ll benefit from new Microsoft-Mail, Calendars, SkyDrive, Photo media, People, and Message apps that are linked with services like Facebook, LinkedIn, and Twitter just by intergrating them with your Microsoft account.
The Start Screen:-
Make it yours – Personalise your start screen with the thing you care about most, Organise and customise it the way you want.
Fast and fluid - Built for speed, Internet Explorer 10 brings you a quicker web experience. Whether loading websites, sharing files, or going to and from sites to apps, it all runs at a speed equal to apps on your own PC.
Intuitive – Surf the web with ease. There when you require, tabs and navigation controls appear at the swipe of your finger. To Share websites with friends—just tap and swipe. And pin individual sites to
A more trusted Web - Increased security, increased privacy, increased peace of mind: Building on innovations such as SmartScreen & Tracking Protection, Internet Explorer has been made to work with the security platform of Windows to give you more control over your personal information and help to keep you safe from online dangers.
Longer Life:-
Great experience across many different devices – Since Windows 8 runs on low-power computers, you can work much longer on a single battery charge. This means you can stay connected so your PC is ready whenever you are. Battery life is Increased and connections are stronger so you’ll be able to find a device to suit you for work or play. Low power requirements are also helped by the increasing number of energy-efficient devices that are designed to work on Windows 8.
Share between devices - Tap and Do works on mobile devices equipped with Near Field Communications. You can tap two devices together and share information, its so simple. Tap and Setup is another feature available on Windows 8 that lets you quickly connect wireless devices, such as keyboards, mice, headphones, and speakers by simply tapping them up against your computer. No more pin’s passwords or complicated setups!
It's Windows reimagined and reinvented from a solid core of Windows 7 quickness and reliability. It's a modern touch interface. It's a Windows for all devices. And it's so simple to try now - whether you're using it for the first time, or moving from Windows 8 consumer preview.
Features:-
Only £79.99 inc VAT.
ORDER NOW
Microsoft Windows 8 64-Bit DVD - OEM (WN7-00403) @ £79.99 inc VAT
Cloud-Connected:-
Apps:-
The Start Screen:-
Longer Life:-
Features:-
ORDER NOW
Microsoft Windows 8 Pro 32-Bit DVD - OEM (FQC-05919) @ £109.99 inc VAT
Cloud-Connected:-
Apps:-
The Start Screen:-
Intuitive – Surf the web with ease. There when you require, tabs and navigation controls appear at the swipe of your finger. To Share websites with friends—just tap and swipe. And pin individual sites to Start for one–click access.
Longer Life:-
Features:-
Only £109.99 inc VAT.
ORDER NOW
Microsoft Windows 8 Pro 64-Bit DVD - OEM (FQC-05955) @ £109.99 inc VAT
Cloud-Connected:-
Apps:-
The Start Screen:-
Longer Life:-
Features:-
ORDER NOW
Use voucher code "win8freeship" to get FREE shipping on Windows 8
if you buy an upgrade version and want to do a re-install in the future, do you have to install win 7 again and then win 8 upgrade again?
Hi, does windows 8 upgrade edition from xp sp3, vista etc include 32 & 64 bit so you can upgrade from 32bit old os to 64bit w8?
I don't think you could upgrade from release candidate with previous versions of windows. No idea if that is still the case with Windows 8 though.
i believe so
would love to pre order but i just hate the horrible tablet style start screen
Once you have installed windows 8 just do a backup and keep it as a base install. No need to install windows 7 then !
No interest in Windows 8. Windows 7 is fine.
thought the upgrade pre order was going to be 25 quid, i was actually tempted to bite at that. 50 is too much for something i can't really see me using though
(btw no i dont mean the buy win 7 now and get win8 for 15 deal)
