- 12 Feb 2006
- Surrey
edit: BEFORE POSTING PLEASE NOTE THIS, I DO NOT HAVE A THERMOSTAT IN MY PROPERTY.
not sure if this would be possible but who knows with the latest tech maybe i will get lucky.
bascially i'm having an issue with heating my place and the random hours i do. i never know what time i'll be returning home so never bother to put heating on a timer as often i'd end up heating a decent sized house to literally come home and go straight to sleep.
what i'd ideally be able to do it switch on an eletric oil filled radiator in the room i select an hour before i get home so that it's warm for me.
is there any thing anyone's heard of that'll allow me to control it being on or off using my mobile (android). i'm thinking it'd have the radiator plugged into it and then it plugs into a socked, it's connected to the wifi and then when the wifi says give power to whatever is plugged into you it does.
if not by mobile, what about by windows pc, which i could then remote log in to using my mobile.
