My latest watercooled build log.... :)
1 Jan 2012
Scottish Borders - UK
I like getting deliveries!!
Let the fun commence this evening.
1st job - cut out the fan mesh. Not the neatest, but what can't be seen doesn't bother me!!
Ignore the drive bay mangled metal. This is a temp measure so I could fit the rad as the Dremel was way too noisey late at night!!
Good news! 60mm push/pull fits in the roof!!
Excuse the poor pics - poor lighting and a camera phone!!
Still waiting to see what the red is like in the day time as I may need to add more dye.
Also I thought I might as well slap the 120 on the rear as it isn't too bad back there. Need to get a decent fan for it now though!
I'm toying with the idea of ordering some red braided cables for the PSU.... Mmmmm.
It would have been a lot neater without the rear 120 - but seeing as I had it and it's not hanging off a mile, I thought I might as well use it.
if you're using a corsair psu (like i see in the background of that photo) then i recommend taking a look at the corsair pre sleeved cables if they offer what you're after. They are verry vibrant, the connections are decent quality, easy to install, not too stiff and are suited for the psu (no need to extend the stock cables). This also means you wont see black standard cables coming from the bottom of the psu, then coloured cables coming through the cable management holes, if that makes sense.
pgreenwo's thread is an example of what the red ones look like: http://forums.overclockers.co.uk/showthread.php?t=18415428&page=5
