I now feel guilty about dumping my log in SA...![]()
I do the same, my lifts aren't important enough to warrant a log
Plus, then there will be a place to view all of steedies posing trunk shots in one place.
Agreed with lots of different ones, a quick view in SA shows:
Powerlifting
Strongman
Ironman
Cycling
Weight loss
Bodybuilding
A cracking range of logs imo![]()
and that's just Delvis' log
I should probably get round to doing one, just to keep track of what im doing everyday!
I'd move my posts to the sub-forum if there was one, then you can post your pony jumping videos all you like in the ratz thread.
How do we get the mods to take notice?
There must be 10-15 logs, and I bet there would be more if a sub-forum was created.
They already have, I've raised it in the Don's Room and it is being discussed. I can't guarantee that a sub-forum will be created for it but at least it has been noted as a request.
Would be busier than the boating/on the water sub forum
And now the Olympic forum is no longer needed either![]()
Good man!
So now you think you're some kind of Messiah, eh?
Wasn't that only created because someone bought a boat?Would be busier than the boating/on the water sub forum![]()
