thanks very informativeso i take it you did an upgrade from win 7 ? and have you noticed any perfornance difference ? is the win 8 upgrade faster on start up and shut down etc ?
I've upgraded from Release Preview which although doesn't save your software it migrates all your data and certain sertings. It's running sweet as a nut and even my skydrive and favourites survived.
Using a full proper Windows 8 32 bit Pro install on my Acer Iconia Tablet.
Seems nice enough, but some gestures just seem sloppy.
Closing windows by sliding your finger down with it, sounds fine until realise the window doesn't move with your finger so it just feels wrong.
Going to highlight an item on the metro screen, have to keep finger on and move down, why not just keep finger on and then bring up the menu?
Oh well.
So you directly upgraded from the RP?? Did it ask for a serial number??
Say you want to run X program as admin (CMD for example)
To highlight it on desktop, you just right click (Bringing up the mini menu)
To get the same effect on the tablet you need to put your finger on it for a little while and then move down to bring up that menu.
By desktop I meant desktop PC.
It's in Metro/New Start that the issue is.
In metro, you right click something, you get options, to get the same options on the tablet you have to press on it a bit and move down (Seems really weird)
Ahhh right - was thinking in Metro itselfI didn't know it worked like that on desktop - thanks, does sound a bit alien - will find out next week
Yeah, it's like a small downward swipe on the tile. If you exaggerate the swipe and keep the pressure on that pulls the tile away to be moved around and reorganised.
Yeah, I think it's a bit gimped to be honest, compared to as you explain normal right clicking in desktop doesn't seem as strange.
Two different types of upgrade here
First is around the license which won't need to validate a previous version, but will allow you to upgrade an existing installation. All the versions you can currently get are full licenses.
If you buy the upgrade license it will still allow you to upgrade an installation, but you'll also have to have a qualifying OS installed or possibly provide it with a key. I don't think there's anyway to test this until it's officially released next week.
As standard Windows 8 installation always asks for a key during install as that defines whether Windows 8 or Windows 8 Pro is installed - also it will automatically activate.
I did, but its not strictly an upgrade it's more of a migration since no software is saved. But yes I went from Release Preview to RTM and it asked me for my product key before installation.
