It would have been a lot neater without the rear 120 - but seeing as I had it and it's not hanging off a mile, I thought I might as well use it.
Id take it off mate.
personally I like to keep everything inside the case.
With the red braided cables and some solid colour fluid you will have a very good looking machine.![]()
Better.....
Still to re-fill, bleed and fit new cables.
With those Corsair pre-braided cables if you pop the pins out you can take that nasty heatshrink off. The red braid is pinned under the molex so it wont come loose. I have no Idea why they used shrink and it looks much better without it.
Looks good. Get some black foam I guess. I would definitely remove that heat shrink. Did it on mine no issues
Have you decided on your next case yet ??
