OCZ Vertex 2...died
1 Sep 2007
Evening gents,
Just wondering if anyone else has had an SSD die for no reason what so ever? Went out Friday night and turned the PC off, Sat when I turned it on...nothing, not seen by the BIOS and wont work if I plug it into a USB caddy.
Any ideas? Anyone heard of this happening before?
With an SSD you won't get any tell tale warning signs that it is about to fail, only in a small amount of cases maybe.
Yeah this problem is well known for the Vertex 2/2E SSD's just to die for no reason. I would get on the OCZ fourm and the staff will tell you what needs doing.
Im 1 of the lucky ones as my Vertex 2E SSD is comming up to 3yrs old and I havent had a single problem.......... BOOM hehe
I just RMA'd my trusty old OCZ vertex 2 bigfoot 3.5" 120GB drive after 2 years of flawless use. Got a replacement quite quickly and then sold it and put the cash towards a 256GB Crucial M4.
My PC just froze one day whilst in Windows and when I rebooted the mobo could not detect the drive on SATA port 1.
Just happened to me, using a Corsair Force 3 240GB though. Windows locked up, restarted and BIOS said it had vanished. Other machines cannot even see the disk exists when connected.
Infuriating, given I only bought the disk in Feb and need it for work!
I was quite lucky, I powered off my PC and restarted and it came back on and booted. I did'nt take any chances though and still RMA'd it and replaced it with the Crucial.
Every Vertex 2e that I've ever owned has failed (think I had about 4 before I finally started getting different models as warranty swaps).
ummm just emailed OCUK regarding the vertex they have as a banner its the 60gb one.
Im wondering if I should get some thing else now then shame cus its only £35
Just make sure your SSD is backed up, if the worst happens you won't lose data - just some time really.
to put it in perspective I have had a crucial m4 die as well but after that no issues, I have the 60 gig vertex 2e in my server and that gives me no hassle either....(yet)
