Are the performance increases just for the 7 series?
Yes.
New tech arc allows more to be done.
the 5 and 6 series simply put is highly optimized already.
I'm going to need a cold day to see what these drivers can do at 1300 MHz![]()
Well you should only have to wait til the end of the weak as snow, sleet and 0 degrees are forecast for certain parts of the uk.
.All those BF3 benchmarks are for single player right?
I'll reserve judgement until i see improvements on a 64 player server.
Good boost in 3D mark 11 on these new drivers.
P7944 3DMarks
with a HD 7850 !!
http://www.3dmark.com/3dm11/4721837
about 1000 point gain.
Aw hell yeah, a 1000 point boost on my 7970 would push me near the top!!!
C'Mon with the leak already![]()
Links seem to be broken!
Where can i get these drivers guys
Cheers.
I downloaded it before it was pulled if anyone wants a copy![]()
While I don't get the BF3 mania, in the hardwarecanucks review
http://www.hardwarecanucks.com/foru...-12-11-never-settle-driver-performance-5.html
in the lowest setting they tested (the one without without MSAA), min frames went up massively. I don't know what the bottleneck in multi-player BF3 is, but I would think that min frames would be more important than max frames.
The guy from hardwarecanucksDO NOT download that. There's a reason why AMD states in their release notes that it shouldn't be distributed (guess Hilbert neglected to read). There are supposedly compatibility issues with the HD 6000 and HD 5000 series cards.
The HD 6000 series could see some optimizations in certain titles.
Yeah good point. I havent seen any problems yet but there must be some for them to be pulled. If anyone wants to try them I am happy to send them to you but do so at your own riskThese are leaked betas after all.
 incase they don't release them today!Yeah i'll like to try plzincase they don't release them today!
Cheers.
