Just having a side thought, but if I decided on para-cord what sizes would I need for flat SATA cables?
And also, as per my question above, does anyone have any resources on how to braid SATA POWER cables? Or any info to share?
Thanks![]()
initially I found it quite difficult. I had a wee play the other night and broke the tool
My hand slipped and twisted the pin off. Ordered another from OCUK and although pricey is made of stainless steel so its much tougher. Got on great guns with it.
Just make sure your going down the outside of the connector sounds obvious but its quite small and sometimes you think your there untill you realise only ones down the outside and one in the middle.
I have done a double 8 pin pci express cable, took about 3 hours.
ordered it on a sunday night and it arrived thursday I think
Space monkey before you order any more shrink, maybe you should watch Lutro customs video on shrinkless sleeving. So buying some generic shrink from maplins etc or a cheaper electronics store and go for that look.
I thought I had enough with 20m of vanilla 10m of copper and 10m of black
I have done 2 x 8 pin pci express cables plus 2 8 pin extensions and about 80% of the 24 pin mobo cable
I'm now out of vanilla and running low on the other 2. Thought I'd have plenty
