Well after extensive gaming/internet and a film, I have not had a single freeze. Without jinxing myself, I am certain these drivers are no good for my set up.
No freezing, yet they are no good?![]()
May be this is a conflict the X79 PCI-e work around .
As tried driver with Gen 2 with no issues so far.
Will have a play after work to confirm
Shame the drivers aren't stable for you Gregster, let's hope the whql's give you the same increases and stability too![]()
I don't need the X79 PCI-e work around to run Gen 3 but the system still froze up with SLI.
Hope you have better luck.
I also found on one card the performance is not as good as 306.23
Clamp & LOD bias no longer working in D3D9.
