iTunes Match is offensively bad
20 Jul 2008
Set this all up but...
1) I can no longer add any music to iTunes whatsoever. What the hell is this about? If I drag and drop an AAC/MP3 file like I used to it does nothing.
2) Half my Playlists aren't supported for some reason. It says something about a playlist within a playlist isn't supported.
"Smart playlists that reference other playlists are not supported by iCloud, and will not be uploaded."
3) It's buggy and slow as hell from my iPhone.
Seriously unimpressed, rant aside though how do I fix the first problem. It's seriously P'd me off. :p
Cheers
I've requested a refund. It's appallingly bad. I ****** knew I should have done my research before buying into Apple's ****.
Why can't you physically sync your iPhone as before and THEN have the option of being able to access the rest of your library from the cloud.
They're supposed to employ the best and brightest at Apple but sometimes they really don't think things through and produce utter ****.
/Rant
did u get a refund and who did you contact?
im having problems with it, ie taking forever to upload tracks left it running 2 days and it uploaded 150 tracks out of 5k , and now it keeps crashing on me all the time.
Works absolutely perfectly for me and my mate.
Keeps my Mac Pro, MacBook Pro and iPhone in sync.
Keeps my mates MacBook Pro, iPad and iPhone in sync.
Are you using iTunes on windows?
I certainly won't be renewing my subscription this year. I'm fed up of downloading all the music I want to my phone after every iOS update. I imagine it's a bit less painless if you have a superfast internet connection, but mine is only 4MB and I have to leave my phone downloading overnight to get all my music back. A simple sync with iTunes would only take an hour or so.
Somehow I managed to update to 5.1.1 without this happening? :confused:
iOS 6 was a new phone so I don't know about that one.
I purchased iTunes match once simply to upgrade all my Music. I would say it's worth buying once. But I have personally never used it to stream to my iPhone. Way too un-reliable when on the road.
On the other hand it does come in handy when somehow losing the odd file and having the option to re-download it if it wasn't originally purchased from iTunes ;)
Have they managed to fix it matching explicit tracks to their clean versions yet? That was a problem at launch...
Like others, I won't be renewing, it's rubbish.. I have to keep turning it off and back on again due to "itunes store problems".
I purchased this a few days ago and I can't say I'm happy with it at all. iTunes wants to upload about 1/3rd of my tracks even though they are clearly on iTunes.
Anyone have the same issue?
I haven't experienced any major problems, seems to have run ok for me for some time, if anything the it was bad on the iPhone and made the Music App so slow but iOS6 has improved it for me. 15k+ songs on it now! :eek:
Works great for me. Some of you are complaining about things that are features, i dont think you get the full point of it.
