The D3H overclocks just fine and being cheaper than the X-D3H you can afford a heatsink to reach 4.4Ghz or maybe a little more. It would be wise to update it's firmware as it can be fussy with GPUs on the old BIOS, just an FYI
If Tam had used the Kingston SSD I linked he would have saved £10 to go towards a good value heatsink. It's all about balance.![]()
Well ideally we would want to use the Samsung 830 SSD.
Like I said it's all about balancing the budget. The cheap £10 keyboard and mouse set isn't a bad idea either as these can be upgraded cheaply enough over time.
I think the Intel SSD's quality is worth the extra £10 over the Kingston.
The i5K has £20ish off whilst on offer, which in my eyes helps pay for the achilles HS to overclock it. Deals change tomoz so makes sense not to hang around too long arguing what's best. I think the OP can balance something nice for the cash with all the info we've given him![]()
That's probably true, but remember that you're using a vertex 2E and I'm using an Agility 3 and neither of us have had issues.
If you listened to half the scaremongering here, we wouldn't own either or they'd be bricked by now![]()
we can... xD
YOUR BASKET
1 x HIS HD 7950 IceQ 3072MB GDDR5 PCI-Express Graphics Card (H795Q3G2M) with FREE FARCRY3, Hitman Absolution, Sleeping Dogs & 20% off MOH Warfighter PC Games £227.99
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £167.99
1 x Samsung 128GB SSD 830 Desktop Series SATA 6Gb/s KIT with Norton Ghost - (MZ-7PC128D/EU) £86.99
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £79.99
1 x PC Power & Cooling Silencer Mk III Series 500W '80 Plus Bronze' Modular Power Supply - White £59.99
1 x Toshiba (7K1000.D) 500GB SATA 6GB/s 32MB Cache - OEM (DT01ACA050) £43.99
1 x Xigmatek Asgard Pro Gaming Case - Black £32.99
1 x Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) £25.99
1 x Samsung SH-S222BB/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM £13.99
1 x Gigabyte KM6150 Keyboard and Mouse Set £9.98
Total : £749.89 (includes shipping : FREE).
and as earlier, next step upgrade is to get an aftermarket heatsink to oc the cpu
Hono I would want to change that PSU to the 550W Corsair one for the same price personally. The case would be down to personal choice and taste.
Otherwise yeah, spot on mate.![]()
Thanks for the replys guys, Tamzzys build looks like the one![]()
