Etiquete with other drivers
If another driver happens to pull in front of you without indicating, it is ill advised to indicate to them that they like to pleasure themselves
Other vehicles
When in the vicinity of another vehicle, contact is not recommended. Should contact happen, the correct procedure is to stop, and deal with the situation calmy. It is not correct to drive away with a hand out the window, with the index and ring fingers extended and separated.
Cyclists and pedestrians
These are not targets. Hitting them will not result in obtaining a new high score. Efforts should be made to avoid them at all costs.
N.B. Cyclists who cross the road whilst performing tricks are exluded from the above notification.
Other vehicles
