Hello,
I wonder if anyone can shed some light on this rather strange issue? I have a 2012 Ford Galaxy Zetec, with the bog standard Ford 6000CD audio system. To this, I connect an iPhone 4S (iOS 6.1) via the Aux socket, as there is no USB on this model.
When a call comes in on the phone, or I use (or rather, try to use) Siri (about the most useless and unreliable feature I have ever encountered on a phone), the music playing cuts out, and the bluetooth handsfree activates, as it should. However, when the call is finished, or Siri fails, as it usually does, the music does not come back on via the Aux input. I have tried switching the audio system on and off, and tried soft and hard resets on the phone, but the only thing that seems to 'reset' the audio is to switch off the car ignition, leave the vehicle, and lock it, so that the audio system completely shuts down, after which, the music will once again come through the Aux socket, when the system is activated. Also, the 'Voice' function of the car fails to operate when this happens, so it seems that the whole handsfree system is 'crashing (?)', or something.
Does anyone else have this issue, or know what might be causing it?
Further, does anyone know if the Ford 6000CD audio system can be completely powered off without exiting and locking the car?
Further still, I have heard that there was a software update to the Ford audio systems last time there was an Apple OS update (to iOS 5.x) - is one available for iOS6, and, if so, how can I get it, and apply it, bearing in mind no USB input?
Thanks for any help with this, which is driving me nuts!
