Ok guys, for those wanting to add more of their apps to the tab so they work on the multi-screen, here is the easiest way to do it:
Can anyone see what I've done wrong?
Better to know how to make your own and figure out an issues as you go. This is a rough guide, not comprehensive but should give a good idea.
Get your list together from the market e.g.
<item>com.quoord.tapatalkpro.activity</item>
[/URL]
com.quoord.tapatalkpro.activity&feature=search_result#?t=W251bGwsMSwyLDEsImNvbS5xdW9vcmQudGFwYXRhbGtwcm8uYWN0aXZpdHkiXQ
Install
Java runtime,
Apktool 1.5,
Notepad++
Grab framework-res.apk and copy to a new folder on your PC c:\apktools with
apktool.jar (rename) &
aapt.exe
Then install the framework (open a cmd window in apktool folder)
Code:
java -jar apktool.jar if framework-res.apk
Now decompile framework-res with apktool
Code:
java -jar apktool.jar d framework-res.apk
See a folder under c:\apktools\framework-res
Make changes to res/values/arrays.xml with Notepad++ “config_multiWindowSupportAppList”
Now compile framework-res.apk back in c:\apktools folder
Code:
java -jar apktool.jar b framework-res.apk
Go to c:\apktools\framework-res\dist and you will now see your new framework-res.apk
Now open the original and new framework-res.apk with winrar or 7zip and copy the new resources.arsc over the one in the original apk. Put the original (modded) apk file back (makes sure you have a working Nandroid first) If you have one of the CWM flash-able zips just swap your framework-res.apk and use CWM.
