We have an older uPVC door in the kitchen, it locks by turning the key (not by pushing up the handle and then turning the key). What i would like to do is make it a bit more secure, ideally with just a straight bolt at the top and bottom as we only use the door a few times a month. The only problem is the door sticks out from the frame as can be seen below:
So sticking a straight bolt on it would look a bit crap, i'd either have to drill a hole in the wall so the straight bolt would go in there and it goes across an inch or so before it gets in to the wall. Or i could stick some wood or something on the frame so it would bring the "receiver" bit of the straight bolt to the same level as the door...both options i reckon will look a proper bodge.
Has anyone got any clever ideas or know of any different bolt/lock types i could use for this?
And before you say buy a new door - i'm too tight for that...and i like the simplicity of a bolt!
Tarp
Tarp
