Hi.
On F7 at the moment and trying to get F18 on.
Qflash doesn't work as the new version is nearly 4mb and I believe I have to use @BIOS this one time and can then use Qflash afterwards.
I know I have got the correct mobo revision (1.0) and I know I shouldn't really use @BIOS but it doesn't work anyway.
@BIOS reports incorrect bios size and I am using version 2.28 of @BIOS (I have tried different links as I have heard there are a couple of versions knocking about.
Can anyone help?
Cheers.
Can anyone help?
Cheers.
