Well, unless your car is randomly sparking everywhere, then what would cause engine oil to catch fire? The block isn't going to be nearly hot enough to cause a fire by radiation alone.
So how do cars catch fire in the first place?
I may have two Audi A3s on my drive at this precise moment![]()
[TW]Fox;23043621 said:Both 2.0 dagdags?![]()
Question for anyone with MMI 3G with SD card readers. Does your MMI/AMI play music through the SD card showing ID3 tags?
I've added a load of music to a 32GB SD card, and whilst everything plays fine, it is showing me file names rather than ID3 tags (of which I've double checked are present in the files). Everything I've read suggests that it shows ID3 tags, but I don't seem to be getting that result.
This, you'll have to change it over in setup.On the VW system it defaults to displaying filenames, you need to go into the setup menu and change it to show id3 tags.
