A GTX 680 question
So no FPS benefit on a single monitor ?
I thought more vram meant more fps in games.
I took the 4GB as meaning double the performance.
It works the same as your computers memory. If you add more memory, it doesn't increase performance and if you are a serious overclocker, it makes it harder to reach top overclocks.
Probably a minus fps as the 4GB has looser memory timings.
+1
Only really going to see the benefit of 4GB over 2GB with tri-SLI and triple monitors.
Games are GPU/bus limited and as such have low FPS before the amount of VRAM comes into it.
Would 2 msi 680 lightnings be worth the money ?
Or would I be better off with 2 msi 680 twin frozrs ?
One would be enough for 1080p. Might want to consider a 7970 though, as that's faster in most games.
I would rather go with nvidia because of the better drivers and its mostly for Arma 3 and arma games seem better with nvidia cards.
The amd hd 7970 has tempted me though.
One is fine for 1080P
How about for a 24" moniter
About the same when overclocked actually.
Within the magic 5% which effectively means even at a margin of error.
In future if I cannot run a game at ultra settings with one 680 , would two 680s allow me to run it at ultra settings ?
It all depends on a few factors, stock or overclocked, reference speeds or factory overclocked, ghz edition and of course which games your playing :D
Are the lightnings worth the extra money , because if not there is a nice SDD i can be buying for this build.
But that said if the 680 lightning is worth it , I will save for that SDD later.
Could someone take out the spot light and put the "I require Stulids assistance symbol on it"
It doesn't matter what size monitor it is, it is the resoloution that matters. I run 3*27" monitors (all 1080P) with 2*MSI Lightning 680s and they are sweet as.
I think you need to do some reasearch, as don't take this the wrong way but you seem pretty clueless when it comes to what you need. You could spend a lot of money on something that will be no better than something far cheaper.
Ok what is your budget and do you intend to overclock?
1080p is 1080p regardless of monitor size (its the same number of pixels on my LG60" plasma as it would be on my 24" 1080p monitor if my monitor wasn't 1200p ;))
I will be getting this monitor.
YOUR BASKET
1 x Benq XL2420T 24" TRUE 120Hz 3D Vision 2.0 Widescreen LED Monitor - Black/Red £319.99
Total : £331.99 (includes shipping : £10.00).
Well atm I can only afford one msi 680 lightning if I want one and the second would come later if I decide on one.
