- 28 Nov 2008
- UK
There isn't much in it. The Steelcase is good - it is usually 'Steelcase or Herman Miller'. I understand, though, that the HM Embody is more up to date in terms of ergonomics and the research that went into it.Any tips on where to get one?
That's looking like a really nice chair and maybe a bit easier on the wallet (or maybe not some of the prices I see are confusing =/ ).
You should try them both. The Steelcase is a chair and supports you like a chair. The Embody supports you almost however you want to sit, but in the best reclined working position, supports you like a tailored chair as if you're floating.
When testing them, look out for amount of contact. The more supportive contact that a chair has across your back and behind, the better (so the load is spread).
shocker lol
