3930K @ 5.1 At Last
8 Feb 2012
U.K
Finaly got my 3930K to 5.1Ghz its not the best chip I got, had to really push volts. Cant go no further then 5.1Ghz.
IDLE
FULL LOAD
Its a Hailea Water Chilled unit bud, only reason I can push volts so hard! at 1st I thought why I got this chiller, kinda of glad now tho after seeing temps!
Nice Sub :) Do you get condensation if you have it too cold and if so, how can you avoid it? (I know you can up the temps but I mean keeping the thermostat low).
Can you give me a link to your chiller please also. I am interested in one of these and what is the noise like?
Yo gregster, yes I do get condensation, but only very little amount! Which I was a bit shocked! Nothing to worry about, however room temp was 10c so may that's why! And the unit was set to 6c at that time.
I'm glad I got it cause, u can really push, and not worry about temps! In goggle type: pc water chiller and its the 3rd link! U should get one depending on your budget I paid £650 for this unit! That 1650 watt of cooling, so 2 CPU'S, and 4 GPU'S, and memory etc if u like!
Noise is loud but unit switches it self on and off every 5 mins, saying that I turned the unit off at the mains cause it was late and didn't want to wake people up! CPU didn't go over 30c for 3 hours! It was ace' no pc fans at all only here pump which was not that loud!
Cheers for the info and that chiller will deffo work for me :) Not sure I could justify that amount but maybe come the summer, I will have changed my mind when temps are hot hot hot.
Nice system and gratz on the clock :)
Will you be brave enough to claim this again during sale on Ebay in the future, or rather stay with "3930K for sale, not overclocked" ? ;-)
Anyone who buys a CPU/GPU/Memory/Mobo/PSU from ebay is taking a massive gamble. I would only buy new or buy from someone I know from the MM.
Do you suggest bunch of liars sell items on Ebay ? :p
BTW, I found lot of "too optimistic" descriptions there, but simple & cogent question clarifies situation in 99%. Rest is return & resolve, unfortunately.
