Corsair 600T with H100i
15 Nov 2010
Hey guys,
Im looking at getting the 600T case with a H100i cooler.
But I have seen some people have issues with the cooler fitting in the top as it touches the ram.
So if I install the cooler on the top, and use the fans in the top extra cover section will the H100i still function just as well?
As the fans will be separated by the mesh that will be between the fans and the radiator.
Also would you have the 2 fans in the top cover sucking air down into the case, or sucking air through the radiator and out?
i have a 600t n a H100 should fit fine, might run into problems if u want a push pull system. if u put fans in the top it will be fine
would have it taking air out of the case as heat rises.
sucking hot air out...therefore also sucking cooler in via the front intake fan.
I've got that case and it's decent if you bin the stock fans and get decent fans to go with it.
And what about performance issues?
As in will it perform worse as there is a mesh in-between, and also the fans are not making a tight connection with the radiator?
nah it'll be fine. the air has got to travel through the mesh which ever side you put the fans
