Samsung SSD error log help
23 Jan 2005
Hi i have the following error log and can't make head or tail of it can anyone point me in the right direction of what it means?
Thanks
27102012/18:37:46:811: UNKNOWN MAGICIANGUI *************************SAMSUNG SSD MAGICIAN STARTED***********************
27102012/18:38:47:638: ERROR SYSTEM TUNING CSysTuning:QueryStatus_Ser: Failed to get handle to CiSvc Service ;Err code: 1060
27102012/18:39:09:090: ERROR SYSTEM TUNING CSysTuning:TuneService: ControlService failed. Service: WSearch ;Err code: 1051
27102012/19:31:04:758: ERROR MAGICIANGUI CSCortApp::LoadImage: Failed to load image at location
27102012/19:32:16:428: ERROR REPORTS CReportInterface::RetrievePrevReport: No reports in file.
27102012/19:32:16:491: WARNING BENCHMARK CBenchmarkManager::DeInit:Some of the sessions did not close voluntarily.Queue has been cleared.
27102012/19:32:16:491: INFO BENCHMARKING Performance benchmark is completed.
27102012/19:51:45:672: WARNING OPTIMIZATION COptimizationMgr::StopAll: No running instance available to stop.
27102012/19:51:45:765: UNKNOWN MAGICIANGUI ****************************************************************************
23112012/08:19:48:843: UNKNOWN MAGICIANGUI *************************SAMSUNG SSD MAGICIAN STARTED***********************
23112012/08:19:57:403: ERROR SYSTEM TUNING CSysTuning:QueryStatus_Ser: Failed to get handle to CiSvc Service ;Err code: 1060
23112012/08:20:02:692: ERROR SYSTEM TUNING CSysTuning:TuneService: ControlService failed. Service: WSearch ;Err code: 1051
23112012/08:20:32:185: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/08:20:35:201: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/08:20:38:216: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/08:20:41:232: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/08:20:44:248: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/08:20:47:263: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/08:20:50:279: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/08:29:43:992: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/08:29:47:008: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/08:29:50:020: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/08:29:53:028: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/08:29:56:043: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/08:29:59:047: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/08:30:02:055: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/09:36:44:413: WARNING OPTIMIZATION COptimizationMgr::StopAll: No running instance available to stop.
23112012/09:36:44:428: UNKNOWN MAGICIANGUI ****************************************************************************
23112012/18:35:16:699: UNKNOWN MAGICIANGUI *************************SAMSUNG SSD MAGICIAN STARTED***********************
23112012/21:26:16:727: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/21:26:19:730: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/21:26:22:733: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/21:26:25:735: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/21:26:28:737: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/21:26:31:740: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/21:26:34:743: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/21:26:37:744: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/21:26:40:745: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/21:26:43:747: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/21:26:46:749: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/21:26:49:760: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/21:26:52:765: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/21:26:55:767: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/21:26:58:769: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/21:27:01:770: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/21:27:04:771: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/21:27:07:772: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/21:27:10:776: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
23112012/21:27:13:777: ERROR OPTIMIZATION COptInterface::TriggerOpt::3 LBA_RANGE_EXCEPTION encountered on Disk S0VYNEAC508390 with Error Code: 5
OP
23 Jan 2005
Thanks run as admin on win 8 in compatability mode as win 7, been running fine but just got the error log file
