you're exactly the same age as me![]()
I had no idea you were that age from your posts, I thought you were like 16 lmao
Damn they lull you in to a false sense of security than slap an invincible boss on you . I Cant kill Pyro pete the invincible![]()
He is in the new dlc
Its his shield i cant drop it to hurt him he is pyro caustic
Can someone "sell" me BL2, i think it looks good but need to know more as in how co-op works..
You can do Co-Op in a number of ways
You can either join a public game or leave your game open for other random people to join.
Or you can play it with friends and leave your game private so only people who you know can join
You don't have to play Co-op. You can do it like any other single player game by yourself.
The logic behind it works quite well, so your friends can jump in and out of your games even if they are at a different point in the story.
The more people in your Co-Op party the more Health Points the enemies have. But you also get better loot drops.
nope, it doesnt
that'll only happen if you screw around with the badass ranks/skills. It's never happened to me.
Anyway, hacky trainer stuff:
thread: http://forum.cheatengine.org/viewtopic.php?t=557381&start=2355&postdays=0&postorder=asc&highlight=
A user by the name of technojacker keeps an up-to-date trainer which can be found here
https://docs.google.com/folder/d/0B...VjV0U/edit?docId=0B_f11g1DlLhDVmhWMUxfN3RFOTA
There's a link in his sig on page 158 for anybody weary about the direct link.
download that, start the game and run the trainer. With teh game running, click on enable (in the trainer). drop back in to the game and run around a bit which allows the trainer to sort itself out, then back to the trainer and look here:
where it says 200, that's the backpack space. Change that to whatever you like. With the backpack space, since the last update, it gets reset to 27 (i think) on every start so you'll have to load the trainer and do this every game if you want to keep the expanded backpack. If you dont, you'll keep the items in the backpack however you want be able to use them.
The trainer does a whole tonne of stuff, like modify the chances to drop legendary loot for example, or teleport to places you wouldnt otherwise be able to reach, or bypass the raid time-lockout, or trick the game in to thinking 4 players are playing, or modify what gets spawned from an Varkid egg to do this:
It's all good fun modifying the game IMO, but try to avoid using it to change your stats - it's quite easy to ruin the game. Stick to the cool stuff
edit:
Oh, and this:
Third person mode!
Hi,
Use a good elec weapong to get his shield down, after that his HP is massive so its a battle of time vs ads level, every so often he does a fireball & acid AOE attack, you need to wash it off using the water thing, however this will spwan ads, you need to alter which one you use as the ads get higher the more times that wheel is turned.
We did it with two peeps, it took a bit of time, having a gunzerker that has a **** weapon is a massive help, plus a siren that can pull all the ads to the boss, keeps them together better to deal with.
You were never supposed to be doing the Raid bosses solo.
it's not the point, i paid the 30 quid to kill them in SP Mode, just like you can with your mates..
