Could a GPU cause a System Crash?
OP
26 Aug 2012
North West
It isn't the PSU. I would try some other drivers for your GPUs. 12.8 iirc was quite a decent set. I assume you have a temp monitor running and can cofirm heat isn't the issue?
Yeh my 7970s didn't go past 60 degrees. My CPU stayed a nice chilly 40-50 degrees. I had logs going so I could see all readings till the point of the crash.
Arent we only upto 12.11? So 12.8? Me=ConfuseD?
OP
26 Aug 2012
North West
12.8 are older drivers. It may have been 12.7 that was reported as very stable but what ever, try a few to confirm if it is driver or other issues.
Where can I get 12.8 64 bit driverS? Can't find anywhere that looks legit.
Just got them but I can onyl find a 32 bit version?
Any help?
