Does this console use the same motion bar as the original Wii? ie: If you have one already plumbed in and stuck to your TV, can you use that one? Or does it use a new format one?
You can use your existing one or replace with the new one (premium pack only). It's exactly the same as the old one and says in the quick start you can use your existing one.
Nothing new there! Quite often they pay in dollars what we pay in pounds! Ripoff!Just realised the American's are paying the best part of £100 less for the same package over here (Shopto's price). Kind of puts me off buying it for a while.
Hang on... Lower models (not premium pack) don't come with the sensor?
Ordered mine from shopto yesterday afternoon and its just been delivered by DPD about five minutes ago. They're usually quick but that's just ridiculous.
Only in US, EU and JP basic models don't have a sensor bar.Hang on... Lower models (not premium pack) don't come with the sensor?![]()
$350 for a Premium (Deluxe) model, £262 if you include VAT compared to £300 here. We are getting a bit stung here but I'm pretty sure it's the retailers setting the console price, rather than Nintendo.Bit of a joke really. £40-50 I could maybe understand but £90 is a bit too much of a difference in all honesty.
That sounds mental! So you walk into a shop and buy a WiiU, get it home... and can't play it because no sensor bar?
Got mine all set up. Downloading an update which could not get any slower![]()
You'll have it sold by the end of the week![]()
Don't turn your console off whatever you do!
Also thats good news, sounds like they have released the patch which definitely wasn't available last night!
WiiU just arrived (sorry Neil!), I'm actually a little hesitant to turn it on as due to how cold it is up here today theres some condensation on the inside of the box.
It that connected over lan or wireless?I almost did as I thought it was stuck at 0%. Almost 2 thirds through.
LEAVE IT FOR A GOOD COUPLE OF HOURS! Not worth the risk surely?
Nah was okay, I just waited until the GamePad screen have completely dried as that was the worst, all working fine now. You know when you wash a window and you wipe it with a towel and it's not dry but not wet, was like that
30% through download on a 10mbit connection and started 21 minutes ago so about 220 kb/s which is a bit painful.
