Can connect to the network but not the internet, really getting annoying now.
Have tried to disable DHCP no luck which OpenDNS server do you use?
).I tried the fifa demo, plays pretty well although i cannot get to grips with the buttons where they are below the second thumbstick. I like the layout of the main controller when you are twin sticking and not using buttons its very comfortable, feeling down for the buttons though is a bit unnatural I feel although im sure it will just take time to get used to.
Only way I get stuff to work on my SuperHub was to disable DHCP and set everything manually and using OpenDNS servers.
208.67.220.220
208.67.222.222
When you disable DHCP you'll need to manually set your IP address, gateway and subnet (not sure if you know this, if you do then you've obviously done that).
Added Soulja, Windle and RRRRodga to friends list, can't find Metalfacemark for some reason. Mine is Zarasi if anyone wants to add me.
On the Wii U it's self?
I'd done that still no joy connects to the network but not the net.
Had my first lockup earlier, bad times. Had to hard reset it
Was only playing about with YouTube app as well
Cannot connect using the virgin media superhub here. Have tried all above settings on the wii u and the turning of dhcp on the superhub menu. Nothing is working![]()
ok superhub now in modem mode and plugged into my older netgear router. connected instantly with no setup required! Thanks roddypoddy! I have the worst headache and angriest fiance at doing this tonight as we both have work at 830 lol
I knew the Wii U CPU wasn't fast, but I'm shocked at how slow it apparently is, 1.25GHz
https://twitter.com/marcan42
Xbox 360's CPU runs at 3.2GHz, no matter how efficient the Wii U CPU could possibly be, it's still got to make up for a lot of clock speed.
