BTW humbug make sure you have the latest patches installed for Skyrim,as these improved framerates. One of the reasons why Skyboost was introduced when Skyrim was launched, was to force the game to use more up to date compiler paths. Better compiler optimisations eventually came in with patch 1.4 and later.
47 is below 60![]()
A spike, didn't even see it while Watching the FPS.
Fascinating, i just updated it to v-1.7.
Frame rates could not be more different, its constantly boinking of the frame rate limiter, GPU usage was 60% to 75% and always at around 60FPS.
Same FRAPS run- Min 47 / Max 62 / Avg 59.372, as i said it did not drop below 60, i really need to get vSync turned off as i can not see any bottle-necking from the CPU yet.
Anyway, i have a bunch of games benched, i just need to figure out which Crysis2 map to bench, i will put the results up later.
is this being done from opening scene ill do it later if it is
okay from opening scene one minute benchmark
2012-11-30 12:41:31 - TESV
Frames: 8963 - Time: 101198ms - Avg: 88.569 - Min: 69 - Max: 120 i5 @ 4.2 will do it later at slower and higher (1080 all settings maxxed 6970)
will do cryis 2 later need to dl it again
can you run first mission on bf3 please for comparision
