A couple of things to try.
1. Are you into the right sata ports on your board?
2. Is the drive running the latest firmware?
3. Is windows installed using the AHCI setting in the bios?
I read that performance drops once they get over 50% full.
Yep, it's in the first 6Gbps port and Intel RST confirms it's running at this speed. It's on firmware 1.4 - I know there's a 1.5 but there shouldn't be much speed difference between them. Yep, on AHCI.
OC your CPU (returns diminish quickly beyond 4800MHz); disable speedstep and CPU power saving options ('Cstates')
overclocking a cpu has nothing to do with your ssd speeds.
I've never had one of these drives to play with (previous experience with other OCZ SSDs put me off their products on a permanent basis), but it isn't credible that these sorts of steps should be necessary.
Hi cammy,
It surely does - particularly on the 4K's in AS SSD.
If you would like to see how high AS SSD results can go with the V4 have a quick look at this thread - http://www.ocztechnologyforum.com/f...718-AS-SSD-Olympics&highlight=as+ssd+olympics
When trying to set land speed records with AS SSD another key factor is disabling non-essential background services. The game is all about stopping any background activity that may distract the AS SSD run.
Regds, JR
Hi JR
what I ment was in this instance overclocking the cpu has nothing to do with it.
The OP's drive is way of the mark of what it can do and this is down to firmware and making sure he's running the latest bios for his board. Im sure of this because Ive had these issues in the past and this is what fixed it for me and im sure it will fix it for the OP.
cheers
ohhh and welcome to the forum mate![]()
