**Today Only 27/11/2012** Asus HD 7970 Matrix Platinum 3072MB & Benq XL2411T 24" TRUE 120Hz 3D Visi
22 Aug 2010
Today only deals, which means more savings! Perfect in time for Christmas. Order now!
Asus HD 7970 Matrix Platinum 3072MB GDDR5 PCI-Express Graphics Card with FREE FARCRY3, Hitman Absolution, Sleeping Dogs & 20% off MOH Warfighter PC Games @ £379.99 inc VAT
The ASUS ROG MATRIX HD 7970 continues the ROG tradition of catering to overclockers who want the fastest and smoothest performance. It meets extreme tuning needs, utilizing a TOP-selected GPU factory-set to 1100MHz. For hardware-level overvolting, customers get VGA Hotwire and the TweakIt interface, with one-press 100% fan speed settings. DIGI+ VRM digital controllers and Super Alloy Power components form the basis of massive 20-phase power delivery. Exclusive GPU Tweak has been enhanced for ROG duty, adding GPU loadline calibration and VRM tuning to an already full range of parameters.
DIY modification of voltages on MATRIX HD 797 becomes simple by removing the need for complicated and risky soldering. Just connect wires from dedicated headers on compatible ROG motherboards to VGA Hotwire connectors on MATRIX HD 7970, after which you can change voltages directly on the hardware level through the ASUS UEFI BIOS or via the Windows-based Ai Suite II.
TweakIt provides flexible overclocking control even when gaming or running benchmarks! The + and - buttons put overvolting adjustments at your fingertips, with more power translating into the faster and smoother gaming you crave and the winning edge you require for intense multiplayer and competitive benchmarking.
Instantly trigger the dual 100mm fans to 100% speed regardless of driver settings. This proves very useful in extreme overclocking and other heavy workload scenarios where rapid heat evacuation and max cooling are a must.
The Safe Mode button resets the graphics card back to default frequencies and BIOS settings. This is a very useful feature for hardware enthusiasts and experimental tuning - think of it like the motherboard's clear CMOS function.
MATRIX HD 7970 is built with carefully-designed massive 20-phase power delivery, unmatched by any other graphics card for the ultimate in performance and spectacular power delivery. This ensures ample room for experimental performance tuning, as its DIGI+ VRM digital voltage regulation design augments precision overclocking capabilities, which are further supported by the use of hardened Super Alloy Power capacitors, chokes, and MOSFETs. These components are forged under extreme pressure and temperatures to increase reliability, power output, and overall card lifespan while eliminating bothersome choke buzzing noise, unlike much tamer reference cards. All these and more enable the absolute best in overclocking potential and experience.
ASUS DirectCU thermal design utilizes all-copper heatpipes so heat is removed efficiently. DirectCU II generates 6X greater airflow yet performs 3X quieter than reference in idle and full load thanks to dual 100mm sound-dampening fans.
A color-coded LED MATRIX indicator at the back of the ROG MATRIX graphics card gives real time and easy-to-understand visual display of the current GPU workload, with colors changing dynamically depending your card’s work load.
Easily fine-tune core and memory clocks, voltages, and fan settings intuitively via sliders or manual value entry. MATRIX HD 7970 arrives with a new ROG edition of GPU Tweak, which adds detailed GPU loadline calibration and VRM frequency tuning, allowing for the most extensive control and adjustment parameters for maximum overclocking potential.
Features:-
- TOP-selected 1100MHz cores run 175MHz higher than reference for smoother gameplay.
- All new MATRIX thermal design utilizes six all-copper heatpipes and 20% bigger dissipation area, achieving 20% cooler and 14dB quieter performance than reference
- Acclaimed DIGI+ VRM with 12-phase Super Alloy Power technology delivers precise digital power and enhanced durability for stable overclocking
- VGA Hotwire allows you to plug and solder wires on the card’s voltage regulators and accurately read and control Vcore, Vmem, and PLL voltages on a hardware level
- GPU Tweak utility helps you modify and tune clock speeds, voltages, and fan performance via an intuitive interface
- One card drives up to six screens with AMD Eyefinity™ 6
- ROG GPU Tweak suite offers the world's first graphics overclocking tool with loadline calibration and VRM overclocking.
Specification:-
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Fastest single GPU graphics card on the planet
- Hugely overclockable
- Vastly cooler running than previous generation
- Quieter running than previous generation
- Compute Power: 3.5 TFLOPS
- Core Clock Speed: 1050MHz
- GPU Boost Speed: 1100MHz
- Primitive Rate: 2 prim / clk
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 6600MHz
- Load / Idle Board Power: <300W / <3W
- Power Connectors: 8-pin + 8-pin
- 20 Phase super alloy design
- Display Outputs: 2x DVI + 4x DP
- 3yr Warranty
- All Orders placed on the 22nd October 2012 and after shall recieve FREE copies of FARCRY3, Hitman Absolution, Sleeping Dogs PC Games along with 20% off the latest Medal of Honor WarFighter. This bundle is worth in the region of £100 and is completely FREE (Subject to availability) - You will recieve your gamecode from 2nd November onwards in the email address you provided when placing your order!
Only £379.99 inc VAT.
ORDER NOW
Benq XL2411T 24" TRUE 120Hz 3D Vision 2.0 Widescreen LED Monitor - Black/Red @ £209.99 inc VAT
The XL2411T demonstrates BenQ's true belief that "gaming is in the details" It has been co-developed with Counter-Strike pro gaming legends to bring you a gaming monitor like no other - from the attentive designs to the exceptional functions. With the precision and speed you would expect from a high-performance gaming monitor, you can now have a vantage point over your opponents in all your game play.
The task of conceptualizing the XL2411T as the ultimate gaming monitor involved a unique collaboration with prominent pro gamers: Tommy "Potti" Ingemarsson, Emil "HeatoN" Christensen, Abdisamad "SpawN" Mohamed, Michael "ahl" Korduner and Christer "fisker" Eriksson. These five names alone are synonymous when it comes to legendary Counter-Strike players. Their accumulated wealth of knowledge and skills helped BenQ develop a monitor that adapts to the needs of gamers to improve their chances of winning.
Poor visibility in dark scenes can cost even the most skilful gamers their game. The Black eQualizer color engine technology is designed to offer an unprecedented level of control and visibility. Dark scenes are brightened without over-exposing the bright areas to preserve vital details, enabling gamers to spot their enemies easily in critical combat and react quickly in any situation.
The XL2411T comes with a stylish S Switch. This distinct remote controller comes with three preset buttons so you're able to customize and save your display settings for gaming, work or entertainment purposes. Use the scroll button on the S Switch to quickly navigate and change the OSD settings. It eliminates the tedious process of adjusting your monitor settings. Now switching seamlessly between the presets is as easy as 1-2-3.
The Display Mode and Smart Scaling features allow you to change the monitor view to suit your liking and to simulate any in-game experience. Interchange instantly between different screen sizes, from 17" (4:3), 19" (4:3), 19"W (16:9), 21.5"W (16:9), 22"W (16:10), 23"W (16:9) to 24"W (16:9), using the Display Mode. Or take advantage of the Smart Scaling feature and enjoy the flexibility to freely scale the screen content to any custom size. You can certainly use the two features together to get the best possible view for any application or game.
The preset FPS mode tailored by HeatoN and SpawN gives you the optimal brightness, contrast, sharpness and color tint in FPS games so you can spot your opponents and track their every move, even in indistinct situations. There are two variations to this special mode this year: the FPS1 mode is designed for Counter-Strike 1.6 and the FPS2 mode for Counter-Strike Source. The perfect combination of form and function provides gamers with the vantage point to always be one step ahead of the game.
With a refresh rate of 120Hz, there's never a lag and every in-game details will be smoothly rendered. Drawing on hyper-speed video processing technology, the XL2411T gives you on-screen action and captivating realism.
Fast response time of 2ms GTG means speed without the smear for an enhanced gaming experience. Fast-moving action and dramatic transitions will be rendered smoothly without the annoying effects of smearing or ghosting. Control your gaming destiny and don't leave it in the hands of slow display.
The newly designed OSD enables you to conveniently change your settings in an intuitive horizontal slide out menu display. This simplistic design makes it easier to navigate between options and settings.
The secret is out. Download special gaming presets used by HeatoN and SpawN so you can see what the pros see. Each mode is fine tuned so you can leverage these exclusive presets used by pro gamers to your own advantage. Users can install these exclusive presets and leverage them to their advantage. More presets from legendary gamers will be released in the future so you can always stay on top of your game.
The Height Adjustment Stand can be operated with just one finger so you can effortlessly adjust the height of the monitor to suit your sight level. Have the monitor way up high, or change it to sit flat on the table. The monitor can also be turned vertically or horizontally and comes with a quick-release VESA mount design. In addition, the sleek headphones hook at the back keeps your desk top neat and tidy.
Certified as NVIDIA® 3D Vision™ 2-ready with the new NVIDIA 3D LightBoost™ technology so you can experience gaming and entertainment like never before with total realism and intensive graphic display
Features:-
- Product Color: Black
- Screen Size: 24"W LED-backlight
- Resolution (max.): 1920 x 1080
- Pixel Pitch: 0.276 mm
- Brightness: 350 cd/m²
- Contrast Ratio: 1,000:1 / DCR:12,000,000:1
- Response Time: 2 ms GtG
- Viewing Angle (L/R;U/D) (CR>=10): 170 / 160
- Display Color: 16.7 million
- Color Gamut: 72%
- Terminals: D-sub / DVI-DL (Dual Link) / HDMI x 1 / Headphone Jack
- Color Temperature: Reddish / Normal / Bluish / User mode
- Features: Black eQualizer, Smart Scaling, FPS Mode, RTS Mode, Game Mode Loader, NVIDIA® 3D Vision™ 2 ready, Senseye 3, AMA
- HDCP
- K-Locker mount
- Height adjustment: 130mm
- Tilt (down / up): -5 / 20
- Swivel (left / right): -45 / 45
- Pivot: 90°
- 571.4 x 516.9 x 149.9 mm
- Gross weight: 6.1 kg
- VESA Wall Mounting (mm): 100 x 100 mm <
- 2yr On-Site Warranty
Only £209.99 inc VAT.
ORDER NOW
I purchased the Benq XL2411T from a different site, mine did not come with the S Switch controller, there is also no mention of this on the Benq website
It is mentioned on their site, on another thread someone asked what the difference was between this and the 2420, when I checked their site it said....and to quote myself
According to the BenQ site compared to the 2420 it has...
no S switch
no dust cover
no Game Mode Loader
no usb hub
no Display Port
only 1 HDMI connector
no S switch
no dust cover
no Game Mode Loader
no usb hub
no Display Port
OK, so we've established that the XL2411T does not come with the S Switch, which leads back to my original statement, the OcUK description lists the XL2411T with the S Switch, is this just a listing error?
