HI there
OK this deal is truly mental, the lowest price in the UK by miles:-
Kingston HyperX Blu 8GB (1x8GB) 1600MHz PC3-12800C10 Single Channel Module (KHX1600C10D3B1/8G) @ £19.99 inc VAT
Kingston's KHX1600C10D3B1/8G is a single module of (8GB) DDR3-1600 CL10 SDRAM (Synchronous DRAM), 2Rx8 memory modules, based on sixteen 512M x 8-bit FBGA components
per module. Total capacity is 8GB. Each module kit has been tested to run at DDR3-1600 at a low latency timing of 10-10-10 at 1.65V. The SPD's are programmed to JEDEC standard latency DDR3-1333 timing of 9-9-9. Each 240-pin DIMM uses gold contact fingers. The JEDEC electrical and mechanical specifications are as follows:
- Kingston Blu KHX1600C10D3B1/8G
- 8GB Single module - 1x 8GB Modules
- DDR3-1600
- CL10
- 1.5v
- 240pin
Was [£29.99] Inc. VAT
Only £19.99 inc VAT.
ORDER NOW
Needless to say, I'd be buying a pair to make it into a 16GB kit, which will work fine by the way.
- DDR3-1600
- CL10
- 1.5v
- 240pin
ORDER NOW
