**OcUK CYBER MONDAY CRAZY KINGSTON MEMORY DEAL!!**
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
OK this deal is truly mental, the lowest price in the UK by miles:-
Kingston HyperX Blu 8GB (1x8GB) 1600MHz PC3-12800C10 Single Channel Module (KHX1600C10D3B1/8G) @ £19.99 inc VAT
Kingston's KHX1600C10D3B1/8G is a single module of (8GB) DDR3-1600 CL10 SDRAM (Synchronous DRAM), 2Rx8 memory modules, based on sixteen 512M x 8-bit FBGA components
per module. Total capacity is 8GB. Each module kit has been tested to run at DDR3-1600 at a low latency timing of 10-10-10 at 1.65V. The SPD's are programmed to JEDEC standard latency DDR3-1333 timing of 9-9-9. Each 240-pin DIMM uses gold contact fingers. The JEDEC electrical and mechanical specifications are as follows:
- Kingston Blu KHX1600C10D3B1/8G
- 8GB Single module - 1x 8GB Modules
- DDR3-1600
- CL10
- 1.5v
- 240pin
Was [£29.99] Inc. VAT
Only £19.99 inc VAT.
ORDER NOW
Needless to say, I'd be buying a pair to make it into a 16GB kit, which will work fine by the way. ;)
Website has 23.99 Inc Vat
Awesome price will have to throw this at a couple friends who are looking to upgrade thie rigs
edit: webby just changed as i posted :D
Ok can someone help me...
If I bought two or four of these for a future system, can I use them in dual channel mode (if used on ivybridge motherboard). I won't be overclocking if at all. I would love the extra memory and would I be able to play latest demanding games and have office and other apps running at same time?
Thanks
Thanks
Hi there
Yes they will work in single, dual, triple or quad channel no problem. :)
Why the hell do I need 16GB memory?
I have no idea, but just bought two anyway. £40 for 16GB. I remember upgrading a 486 from 4MB to 16MB and it cost a small fortune.
How far we have come.
I have four 4Gb GSkill 1333 DIMMS at the moment - would I be able to replace two of these with two of the above sticks ?
Oh, and thanks for the Haribo at the Gadget Show !
cj
cj
Do you mean replacing two of the four sticks with the Kingston RAM, so you'd have two sticks of GSkill and two of Kingston?
