+1
I'm guessing it'll be a write off
The merc driver probably does have whiplash from the looks of that impact!
It still doesn't stop the car behind ploughing into you?Looks like you need to leave a bigger gap in traffic
No one keeping a safe distance.
Just got off the phone with Admiral, they said the Mercedes will be at fault and I will not have to pay the excess. It should not affect my no claims and premium.... it better not!
Plenty of techniques can help. One is leaving a gap to move into and also keeping your foot on the brake when stopped
Last I checked there was no such thing as a safe distance when stationary.
Hmmm....
Some of that energy going into doing work moving your vehicle vehicle and the offenders vehicle, rather than crushing the car, is actually better.
If I see a car about to plough into the back of me, unless I have an immovable object (wall, large vehicle etc.) in front of me (or being thrown into cross traffic) I'm letting go of the brakes.
There is actually, you should be able to see the back tires of the car in front touching the tarmac
There is actually, there is even an explicit 5 metre gap stated in the highway code for when stopped in a tunnel.
Keeping the brake pedal on is more to do with the brake lights being on and giving an indication you are stopped/stopping. Proven to reduce chances of being rear ended as automatic cars are rear ended less than manuals. Plus it reduces the chance of whiplash
If you leave a bigger gap it means you can brake more gently which then gives the person behind more chance to react.
You need to drive in a way to help other drivers. You don't want to be 'dead right'.
