Are you sure that's a direct translation from your computer, maybe 1150 is really only 700. a lot of people say 1000watts is total overkill. I think 800 is the max.
That was my power draw on 3D11 with 1.3v going through the cards.
750w from the wall is actually only about 600-650w from your PSU.
Meaning your current PSU is fine, but running a PSU at near maximum capacity isn't the best way...if you've got the spare money - upgrade to a decent 750-850w PSU. If not, shouldn't worry too much as the Corsair units are pretty decent.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-005-XF&groupid=701&catid=123&subcat=1497
a psu works best at 80% or under,any higher and its gonna be less efficient,plus a smaller psu will have to work harder/run hotter and probably go pop quicker than a larger psu
doesnt matter how large the psu is the components will only use what it needs
Alright sounds like amplifiers for audio, is that XFX a good choice compared to a Corsair? Why are Corsair ones so damn expensive?
XFX are also Seasonic PSU's![]()
What wattage would people reccommend for XFIRE OC'D 7850s and an OC'D CPU?
With a few fans, SSD and 2 HD's?
If it is one 6 pin connector, AMD recommends a 500W PSU (for one GPU) and if it is two 6 pin connectors, AMD recommend a 600W PSU. Going by this, I would feel a 650 is pushing it (especially with a tidy overclock). Somebody else with more knowledge would have to confirm though.
When I bought my 750W Antec TP a few years ago, I felt it would be plenty and it cost me just shy of £100. After seeing several upgrades, the PSU got switched from different hardware-cases and did the job. I never imagined I would end up with 3 screens and two GPU's and wished I had invested in a bigger PSU the first time (hindsight is great).
Moral of the story is, you can't regret having too much power and buy what your budget allows.
Thanks, I have an 850W PSU right now, but it's too loud, the fan seems to be at 100% at idle, I can hear it above everything. I'm gonna buy a new Corsair 760i or 860i (fan doesn't even come on until load), just trying to work out whether it's worth the extra £10-£15 more on 860W.
