"Guide" Fix Youtube Buffer issue On Virgin Media :)
25 Nov 2011
The KOP
Update
Now Try without Blocking any IPs, Virgin Media seems to have now fixed this buffering problem.
Hello I know a lot of us on here, who with VM been having buffer issue with HD YouTube videos. Well some guy over on the VM forums seems to have found a nice easy fix :)
I have just followed the guide and once I finished noticed Youtube was super fast like old day lol
Blocking 62.252.0.0/16 Range seems to be the better option.
What you need to do is Block this IP address 62.252.44.12 and that's it :D
Block an IP or IP Range in Windows Firewall
https://support.powerdnn.com/KB/a482/block-an-ip-or-ip-range-using-windows-firewall.aspx
Give it a try guys.
And I thought I was coming in here to find an actual solution to the buffer issue... :rolleyes:
sigh... a quick type into the URL bar tells me the IP address is for google, dont bother....
Merry Christmas :o
Merry Christmas :o
Wow you really didn't even try did you? So like 8 of us all lie about this?
Tried it - sort of worked, sort of didn't. A video I was watching is now loading at 720p fine, however any other video now has a 30 second timeout before it even tries to load and then only 50% of them will even buffer, the rest won't even load
- GP
- GP
Have a link see if I can load it?
It's the Tekkit Videos from Yogscast, they're fine (For everybody but me on Virgin!!)
- GP
Clicked couple of them, There buffering fine here. Will see how this go's on peak time tomorrow.
So far YouTube is using a lot more of my speed, When I right click show video info I can see its using much more than before.
Just tried the rule on the router as well as the windows firewall and clearly not working. I'm sure there's a possibility it is working for some people, however it is definitely not a true fix and won't work for everybody
- GP
Same did nothing for me at all
Edit: Did this as found on vm forum Block the range 62.252.0.0/16 and it worked for me so must be multiple cache addresses
Blocking the entire /16 assignment seems to have done the trick. Good work OP + DAvE18.
Note: I blocked it using Windows Firewall and Virgin have replaced the ""SuperHub" with a (Just as bad) D-Link DIR-615 after my brother moaned about the terrible WIFI, so although I'm still testing and all looks good (using Google DNS)
- GP
