**** It's big and it's back ****
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi
Guess whats arrived back in our warehouse after being out of stock for so long.
Logitech G27 Racing Wheel - PC / PS2 / PS3 (941-000047) @ £199.99 inc VAT
A simulator-grade racing wheel, the Logitech G27 Racing Wheel is designed to deliver the definitive sim racing experience for the PC and Playstation 3. Its powerful, dual-motor force feedback mechanism with helical gearing smoothly and accurately simulates traction loss, weight shift and road feel, with exceptionally quiet steering action. The six-speed shifter with push-down reverse gear allows you to quickly choose exactly the right gear. New RPM/shift indicator LEDs let you know when you should shift gears; the 28-cm leather-wrapped rim provides hours of comfortable, true-to-life racing; and steel accelerator, brake and clutch pedals deliver precise control for heightened realism.
- Dual-motor force feedback mechanism with helical gearing
- RPM/shift indicator
- Sixteen programmable buttons plus D-Pad
- 900 degree wheel rotation
- Ultra-precise optical encoding
- Carpet Grip System
- 6 Speed Gear Shifter
- Steel gas, brake and clutch pedal
- Steel ball bearings
- Works with PC, PS2, PS3
Only £199.99 inc VAT.
ORDER NOW
Does the movement of the wheel/pedals (feedback, smoothness) on the G27 feel any different to the G25?
The G27 is a little quieter, but the feedback feels identical. As Ace said, don't bother 'upgrading'. Save that money for a Trustmaster T500 ;)
I would feel a little bit upset if i knew someone was buying this to use on a ps2...
However, in a fat contradiction to myself, I would love to play some old need for speeds on it.
I had the G25 a couple of years ago but sold it to a friend when I moved house. I loved it and wondering if worth buying the G27 for a better "feel" at the cost of losing the forward-back shifter option on the H box.
What is the warranty on this? It doesn't appear in the listing
It feels almost identical, I've only stuck with my G25 because I use the sequential a lot. Warranty is 2 years as per Logitech's site.
Is that just a stock picture, or is it really sold here with the gear lever on the wrong side? That must be so weird to use if you know how to drive an actual car.
E: Oh I just checked the store page and it's removable. It looks like it's fully attached in the main picture.
I'd have thought they'd have come down in price by now.
I bought one in September 2010 for £199.99 and it came also with Gran Turismo 5 for that price.
